[点晴永久免费OA]Encode/Decode RealVNC password
2017年6月2日 12:25 本文热度 12393
下面是我收集的VNC密码加密和解密C#源代码:
public static string EncryptVNC(string password)
        if (password.Length > 8)
            password = password.Substring(0, 8);
        if (password.Length < 8)
            password = password.PadRight(8, '\0');
        byte[] key = { 23, 82, 107, 6, 35, 78, 88, 7 };
        byte[] passArr = new ASCIIEncoding().GetBytes(password);
        byte[] response = new byte[passArr.Length];
        char[] chars = { '0', '1', '2', '3', '4', '5', '6', '7', '8', '9', 'A', 'B', 'C', 'D', 'E', 'F' };
        // reverse the byte order
        byte[] newkey = new byte[8];
        for (int i = 0; i < 8; i++)
            // revert desKey[i]:
            newkey[i] = (byte)(
                ((key[i] & 0x01) << 7) │
                ((key[i] & 0x02) << 5) │
                ((key[i] & 0x04) << 3) │
                ((key[i] & 0x08) << 1) │
                ((key[i] & 0x10) >> 1) │
                ((key[i] & 0x20) >> 3) │
                ((key[i] & 0x40) >> 5) │
                ((key[i] & 0x80) >> 7)
        key = newkey;
        DES des = new DESCryptoServiceProvider();
        des.Padding = PaddingMode.None;
        des.Mode = CipherMode.ECB;
        ICryptoTransform enc = des.CreateEncryptor(key, null);
        enc.TransformBlock(passArr, 0, passArr.Length, response, 0);
        string hexString = String.Empty;
        for (int i = 0; i < response.Length; i++)
            hexString += chars[response[i] >> 4];
            hexString += chars[response[i] & 0xf];
        return hexString.Trim().ToLower();
然后是解密:
public static string DecryptVNC(string password)
        if (password.Length < 16)
            return string.Empty;
        byte[] passArr = ToByteArray(password);
            // revert key[i]:
            newkey[i] = (byte)(
        key = newkey;
        ICryptoTransform dec = des.CreateDecryptor(key, null);
        dec.TransformBlock(passArr, 0, passArr.Length, response, 0);
        return System.Text.ASCIIEncoding.ASCII.GetString(response);
下面这个函数是必须的:
public static byte[] ToByteArray(String HexString)
        int NumberChars = HexString.Length;
        byte[] bytes = new byte[NumberChars / 2];
        for (int i = 0; i < NumberChars; i += 2)
            bytes[i / 2] = Convert.ToByte(HexString.Substring(i, 2), 16);
        return bytes;
在顶部加上:
using System.Security.Cryptography;
该文章在 2018/1/2 18:04:14 编辑过
