C# 读取eml文件 例子(解析eml文件)
2017年10月21日 18:25 本文热度 12627
【实例简介】标题/邮箱/信件内容等
【实例截图】
【核心代码】
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
using System.IO;
using System.Linq;
using System.Windows.Forms;
using ADODB;
using CDO;
using System.Diagnostics;
using Stream = ADODB.Stream;
using System;
namespace EmlReader.WinForm
    public partial class EmlViewer : Form
        public EmlViewer()
            InitializeComponent();
        public void OpenEml(string filepath)
            try
                var stream = new StreamClass();
                stream.Open();
                stream.LoadFromFile(filepath);
                stream.Flush();
                var mail = new MessageClass();
                mail.DataSource.OpenObject(stream, "_Stream");
                mail.DataSource.Save();
                fromBox.Text = mail.From;
                toBox.Text = mail.To;
                ccBox.Text = mail.CC;
                bccBox.Text = mail.BCC;
                subjectBox.Text = mail.Subject;
                bodyBox.Text = mail.TextBody;
                attachmentsPanel.Controls.Clear();
                foreach (IBodyPart attachment in mail.Attachments)
                    var linkLabel = new LinkLabel
                                            Text = attachment.FileName,
                                            AutoSize = true,
                    linkLabel.Links.Add(0, linkLabel.Text.Length, attachment.GetDecodedContentStream());
                    linkLabel.LinkClicked  = LinkLabelLinkClicked;
                    linkLabel.Disposed  = LinkLabelDisposed;
                    attachmentsPanel.Controls.Add(linkLabel);
                stream.Close();
            catch (Exception)
                MessageBox.Show(this, "An error occured while opening the file", "Email could not be opened",
                                MessageBoxButtons.OK, MessageBoxIcon.Error);
        static void LinkLabelDisposed(object sender, EventArgs e)
            var linkLabel = sender as LinkLabel;
            if (linkLabel == null) return;
            foreach (LinkLabel.Link link in linkLabel.Links)
                ((Stream)link.LinkData).Close();
        static void LinkLabelLinkClicked(object sender, LinkLabelLinkClickedEventArgs e)
            var fileName = linkLabel.Text;
            linkLabel.LinkVisited = true;
            var stream = e.Link.LinkData as Stream;
            if (stream == null) return;
            var tempFile = Path.Combine(Path.GetTempPath(), fileName);
            stream.SaveToFile(tempFile, SaveOptionsEnum.adSaveCreateOverWrite);
            Process.Start(tempFile);
        private void EmlViewerDragDrop(object sender, DragEventArgs e)
            var files = (string[])e.Data.GetData(DataFormats.FileDrop);
            OpenEml(files.First());
        private void EmlViewerDragEnter(object sender, DragEventArgs e)
            if (e.Data.GetDataPresent(DataFormats.FileDrop)) e.Effect = DragDropEffects.Copy;
        private void OpenButtonClick(object sender, EventArgs e)
            openFileDialog.ShowDialog(this);
        private void OpenFileDialogFileOk(object sender, System.ComponentModel.CancelEventArgs e)
            var dialog = sender as FileDialog;
            if (dialog == null) return;
            OpenEml(dialog.FileName);
该文章在 2017/10/21 18:25:30 编辑过
