C#完美任意设置webBrowser框架默认的IE内核版本
2019年11月13日 10:17 本文热度 9213
通常情况下,我们直接调用C#控件webBrowser的时候,默认是IE7内核,用webBrowser控件打开IE内核检测网站内容是非常难看滴。
我们在程序里面写入以下代码:
        /// <summary>
        /// 修改注册表信息来兼容当前程序
        /// </summary>
        static void SetWebBrowserFeatures(int ieVersion)
            // don''t change the registry if running in-proc inside Visual Studio
            if (LicenseManager.UsageMode != LicenseUsageMode.Runtime)
                return;
            //获取程序及名称
            var appName = System.IO.Path.GetFileName(System.Diagnostics.Process.GetCurrentProcess().MainModule.FileName);
            //得到浏览器的模式的值
            UInt32 ieMode = GeoEmulationModee(ieVersion);
            var featureControlRegKey = @"HKEY_CURRENT_USER\Software\Microsoft\Internet Explorer\Main\FeatureControl\";
            //设置浏览器对应用程序(appName)以什么模式(ieMode)运行
            Registry.SetValue(featureControlRegKey + "FEATURE_BROWSER_EMULATION",
                appName, ieMode, RegistryValueKind.DWord);
            // enable the features which are "On" for the full Internet Explorer browser
            //不晓得设置有什么用
            Registry.SetValue(featureControlRegKey + "FEATURE_ENABLE_CLIPCHILDREN_OPTIMIZATION",
                appName, 1, RegistryValueKind.DWord);
            //Registry.SetValue(featureControlRegKey + "FEATURE_AJAX_CONNECTIONEVENTS",
            //    appName, 1, RegistryValueKind.DWord);
            //Registry.SetValue(featureControlRegKey + "FEATURE_GPU_RENDERING",
            //Registry.SetValue(featureControlRegKey + "FEATURE_WEBOC_DOCUMENT_ZOOM",
            //Registry.SetValue(featureControlRegKey + "FEATURE_NINPUT_LEGACYMODE",
            //    appName, 0, RegistryValueKind.DWord);
        /// <summary>
        /// 获取浏览器的版本
        /// </summary>
        /// <returns></returns>
        static int GetBrowserVersion()
            int browserVersion = 0;
            using (var ieKey = Registry.LocalMachine.OpenSubKey(@"SOFTWARE\Microsoft\Internet Explorer",
                RegistryKeyPermissionCheck.ReadSubTree,
                System.Security.AccessControl.RegistryRights.QueryValues))
                var version = ieKey.GetValue("svcVersion");
                if (null == version)
                    version = ieKey.GetValue("Version");
                        throw new ApplicationException("Microsoft Internet Explorer is required!");
                int.TryParse(version.ToString().Split(''.'')[0], out browserVersion);
            //如果小于7
            if (browserVersion < 7)
                throw new ApplicationException("不支持的浏览器版本!");
            return browserVersion;
        /// <summary>
        /// 通过版本得到浏览器模式的值
        /// </summary>
        /// <param name="browserVersion"></param>
        static UInt32 GeoEmulationModee(int browserVersion)
            UInt32 mode = 11000; // Internet Explorer 11. Webpages containing standards-based !DOCTYPE directives are displayed in IE11 Standards mode.
            switch (browserVersion)
                case 7:
                    mode = 7000; // Webpages containing standards-based !DOCTYPE directives are displayed in IE7 Standards mode.
                    break;
                case 8:
                    mode = 8000; // Webpages containing standards-based !DOCTYPE directives are displayed in IE8 mode.
                    break;
                case 9:
                    mode = 9000; // Internet Explorer 9. Webpages containing standards-based !DOCTYPE directives are displayed in IE9 mode.
                    break;
                case 10:
                    mode = 10000; // Internet Explorer 10.
                    break;
                case 11:
                    break;
            return mode;
然后在在构造函数中引用:
   SetWebBrowserFeatures(11);
关闭程序重启,可以看到已经设置为IE11的内核了。
该文章在 2019/11/13 10:17:17 编辑过
