【C#】获取.net Framework框架的安装目录
2021年5月11日 17:54 本文热度 8835
方法一:
string frameworkInstallDir = System.Runtime.InteropServices.RuntimeEnvironment.GetRuntimeDirectory();
方法二:
public static string GetFrameworkDirectory()
    // This is the location of the .Net Framework Registry Key
    string framworkRegPath = @"Software\Microsoft\.NetFramework";
    // Get a non-writable key from the registry
    RegistryKey netFramework = Registry.LocalMachine.OpenSubKey(framworkRegPath, false);
    // Retrieve the install root path for the framework
    string installRoot = netFramework.GetValue("InstallRoot").ToString();
    // Retrieve the version of the framework executing this program
    string version = string.Format(@"v{0}.{1}.{2}\",
    Environment.Version.Major,
    Environment.Version.Minor,
    Environment.Version.Build);
    // Return the path of the framework
    string path = System.IO.Path.Combine(installRoot, version);
    if (path.EndsWith("\\"))
        return path;
    else
        return path + "\\";
该文章在 2021/5/11 17:54:20 编辑过
