几个C#图片操作公共库:加载、压缩、base64等
2024年6月3日 11:19 本文热度 6041
这里包括图片加载、压缩、base64等,大家可以收藏一下,用起来方便。
代码如下:
public static class ImageFun
#region 图片
public static EncoderParameters GetEncoderParas(long picquality)
EncoderParameters eps = new EncoderParameters(1);
Encoder ec = Encoder.Quality;
EncoderParameter ep = new EncoderParameter(ec, picquality);
eps.Param[0] = ep;
return eps;
public static ImageCodecInfo GetJpegCodecInfo()
ImageCodecInfo[] arrayICI = ImageCodecInfo.GetImageEncoders();
ImageCodecInfo jpegICIinfo = null;
for (int x = 0; x < arrayICI.Length; x++)
if (arrayICI[x].FormatDescription.Equals("JPEG"))
jpegICIinfo = arrayICI[x];
break;
return jpegICIinfo;
public static System.Drawing.Image GetImage(string path)
FileStream fs = new FileStream(path, FileMode.Open);
Image result = Image.FromStream(fs);
fs.Close();
return result;
public static Bitmap GetImageFromBase64(string base64string)
byte[] b = Convert.FromBase64String(base64string);
MemoryStream ms = new MemoryStream(b);
Bitmap bitmap = new Bitmap(ms);
return bitmap;
public static string GetBase64FromImage(string imagefile)
string strbaser64 = "";
try
Bitmap bmp = new Bitmap(imagefile);
MemoryStream ms = new MemoryStream();
bmp.Save(ms, System.Drawing.Imaging.ImageFormat.Jpeg);
byte[] arr = new byte[ms.Length];
ms.Position = 0;
ms.Read(arr, 0, (int)ms.Length);
ms.Close();
strbaser64 = Convert.ToBase64String(arr);
catch (Exception)
return "";
return strbaser64;
/// <summary>
/// 按照比例缩小图片
/// </summary>
/// <param name="srcImage">要缩小的图片</param>
/// <param name="percent">缩小比例</param>
/// <returns>缩小后的结果</returns>
public static Bitmap PercentImage(Image srcImage, double percent)
// 缩小后的高度
int newH = int.Parse(Math.Round(srcImage.Height * percent).ToString());
// 缩小后的宽度
int newW = int.Parse(Math.Round(srcImage.Width * percent).ToString());
try
// 要保存到的图片
Bitmap b = new Bitmap(newW, newH);
Graphics g = Graphics.FromImage(b);
// 插值算法的质量
g.InterpolationMode = InterpolationMode.Default;
g.DrawImage(srcImage, new Rectangle(0, 0, newW, newH), new Rectangle(0, 0, srcImage.Width, srcImage.Height), GraphicsUnit.Pixel);
g.Dispose();
return b;
catch (Exception)
return null;
/// <summary>
/// 按照指定大小缩放图片
/// </summary>
/// <param name="srcImage"></param>
/// <param name="iWidth"></param>
/// <param name="iHeight"></param>
/// <returns></returns>
public static Bitmap SizeImage(Image srcImage, int iWidth, int iHeight)
try
// 要保存到的图片
Bitmap b = new Bitmap(iWidth, iHeight);
// 插值算法的质量
g.InterpolationMode = InterpolationMode.HighQualityBicubic;
g.DrawImage(srcImage, new Rectangle(0, 0, iWidth, iHeight), new Rectangle(0, 0, srcImage.Width, srcImage.Height), GraphicsUnit.Pixel);
g.Dispose();
return b;
catch (Exception)
return null;
/// <summary>
/// jpeg图片压缩
/// </summary>
/// <param name="sFile"></param>
/// <param name="outPath"></param>
/// <param name="flag"></param>
public static bool GetPicThumbnail(string sFile, string outPath, int flag)
if (File.Exists(outPath)) File.Delete(outPath);
System.Drawing.Image iSource = System.Drawing.Image.FromFile(sFile);
ImageFormat tFormat = iSource.RawFormat;
//以下代码为保存图片时,设置压缩质量
EncoderParameters ep = new EncoderParameters();
long[] qy = new long[1];
qy[0] = flag;//设置压缩的比例1-100
EncoderParameter eParam = new EncoderParameter(System.Drawing.Imaging.Encoder.Quality, qy);
ep.Param[0] = eParam;
try
break;
if (jpegICIinfo != null)
iSource.Save(outPath, jpegICIinfo, ep);//dFile是压缩后的新路径
else
iSource.Save(outPath, tFormat);
return true;
catch
return false;
finally
iSource.Dispose();
#endregion
该文章在 2024/6/3 11:20:27 编辑过
