C#winform怎样实现动态生成控件
2024年10月18日 12:51 本文热度 5244
概述
动态创建添加控件,可以在一个大容器里一次性放入多个控件。例:根据文本框中输入的数字 给flowLayoutPanel1 添加多少个button。窗体设计中,需要什么控件就从工具箱里拖出一个控件“挂”在窗体上。其实,窗体上的控件,不但可以“拖”,还可以用代码动态生成。动态生成控件,对需要相同的大量的控件还是比较有用的。
实现方式
1、加载数据,往panel添加Label 控件。
 private void LoadRoomType()        {            DataTable dtRoomType = _roomTypeBLL.GetModelList("", "Code");            pnlRoomType.Controls.Clear();            int padding = 5;            int x = padding, y = padding;            pnlRoom.Controls.Clear();            foreach (DataRow item in dtRoomType.Rows)            {                Label lbl = new Label();                lbl.Text = string.Format("{0}", item["Names"]);                lbl.Image = btnRoomType.Image;                lbl.Cursor = Cursors.IBeam;                lbl.TextAlign = btnRoomType.TextAlign;                lbl.Font = btnRoomType.Font;                lbl.ForeColor = btnRoomType.ForeColor;                lbl.Size = btnRoomType.Size;                lbl.Location = new Point(x, y);                lbl.Tag = item;                lbl.Click += new EventHandler(lbl_Click);                lbl.MouseEnter += new EventHandler(lbl_MouseEnter);                lbl.MouseLeave += new EventHandler(lbl_MouseLeave);                x += lbl.Width + padding;                if (x + lbl.Width > pnlRoomType.Width)                {                    x = padding;                    y += lbl.Height + padding;                }                pnlRoomType.Controls.Add(lbl);            }            int height = y + (x != padding ? pnlRoomType.Height : 0) + padding;            int addHeight = height - pnlRoomType.Height;            pnlRoom.Top = pnlRoom.Top + addHeight;            pnlRoom.Height = pnlRoom.Height - addHeight;            pnlRoomType.Height = pnlRoomType.Height + addHeight;            if (dtRoomType.Rows.Count > 0)                LoadRoomByTypeID(dtRoomType.Rows[0], 0);        }
2、定义Label 的点击事件。
  void lbl_Click(object sender, EventArgs e)        {            try            {                Label lbl = sender as Label;                DataRow row = lbl.Tag as DataRow;                LoadRoomByTypeID(row, 0);             }            catch (Exception ex)            {
3、定义Label 的鼠标事件。
   #region lbl_MouseLeave        void lbl_MouseLeave(object sender, EventArgs e)        {            Label lbl = sender as Label;            lbl.Font = new Font(lbl.Font, FontStyle.Regular);            lbl.Cursor = Cursors.Default;            lbl.ForeColor = btnRoomType.ForeColor;        }        #endregion        #region lbl_MouseEnter        void lbl_MouseEnter(object sender, EventArgs e)        {            Label lbl = sender as Label;            lbl.Font = new  Font(lbl.Font, FontStyle.Bold);            lbl.Cursor = Cursors.IBeam;        }        #endregion
效果
该文章在 2024/10/19 12:24:09 编辑过
