C#强制开启Windows系统远程桌面服务,取消仅允许运行使用网络级别身份验证(NLA)的远程桌面的计算机连接限制
2025年3月7日 12:14 本文热度 7958
以下是实现强制开启Windows 远程桌面服务并禁用网络级别身份验证(NLA)的C#代码示例:
using System;
using Microsoft.Win32;
using System.ServiceProcess;
using System.Diagnostics;
using System.Security.Principal;
class EnableRemoteDesktop
        if (!IsAdministrator())
            Console.WriteLine("请以管理员权限运行此程序。");
            return;
        try
            ConfigureTermService();
            EnableRdpThroughRegistry();
            DisableNlaThroughRegistry();
            RestartTermService();
            Console.WriteLine("远程桌面已成功启用,NLA限制已取消!");
        catch (Exception ex)
            Console.WriteLine($"操作失败: {ex.Message}");
    static bool IsAdministrator()
        var identity = WindowsIdentity.GetCurrent();
        var principal = new WindowsPrincipal(identity);
        return principal.IsInRole(WindowsBuiltInRole.Administrator);
    static void ConfigureTermService()
        try
            // 设置服务为自动启动
            ProcessStartInfo scConfig = new ProcessStartInfo
                FileName = "sc",
                Arguments = "config TermService start= auto",
                UseShellExecute = false,
                CreateNoWindow = true
            Process.Start(scConfig)?.WaitForExit();
            // 确保服务运行
            using (ServiceController service = new ServiceController("TermService"))
                if (service.Status != ServiceControllerStatus.Running)
                    service.Start();
                    service.WaitForStatus(ServiceControllerStatus.Running, TimeSpan.FromSeconds(30));
            throw new Exception($"配置远程桌面服务失败: {ex.Message}");
    static void EnableRdpThroughRegistry()
        try
            using (RegistryKey key = Registry.LocalMachine.OpenSubKey(
                @"SYSTEM\CurrentControlSet\Control\Terminal Server", true))
                key?.SetValue("fDenyTSConnections", 0, RegistryValueKind.DWord);
            throw new Exception($"修改注册表启用RDP失败: {ex.Message}");
    static void DisableNlaThroughRegistry()
        try
            using (RegistryKey rdpKey = Registry.LocalMachine.OpenSubKey(
                @"SYSTEM\CurrentControlSet\Control\Terminal Server\WinStations\RDP-Tcp", true))
                rdpKey?.SetValue("UserAuthentication", 0, RegistryValueKind.DWord);
            throw new Exception($"禁用NLA失败: {ex.Message}");
    static void RestartTermService()
        try
                if (service.Status == ServiceControllerStatus.Running)
                    service.Stop();
                    service.WaitForStatus(ServiceControllerStatus.Stopped, TimeSpan.FromSeconds(30));
                service.Start();
            throw new Exception($"重启服务失败: {ex.Message}");
使用说明:
  1. 以管理员身份运行:
    • 在Visual Studio中创建项目时,需在app.manifest中添加管理员权限请求:
<requestedExecutionLevel level="requireAdministrator" uiAccess="false" />
  1. 关键操作说明:
    • fDenyTSConnections设为0启用远程桌面
    • UserAuthentication设为0禁用NLA
    • 服务配置: 将TermService服务设置为自动启动并确保运行状态
    • 注册表修改:
    • 服务重启: 确保注册表修改生效
  2. 附加建议(可选):
// 添加防火墙规则(如果需要)
static void AddFirewallRule()
    try
        ProcessStartInfo firewall = new ProcessStartInfo
            FileName = "netsh",
            Arguments = "advfirewall firewall add rule name=\"Remote Desktop\" dir=in protocol=TCP localport=3389 action=allow",
        Process.Start(firewall)?.WaitForExit();
        Console.WriteLine($"防火墙规则添加失败: {ex.Message}");
注意事项:
  • 修改注册表前建议备份
  • 禁用NLA会降低安全性,建议仅在可信网络环境中使用
  • 部分服务器版本可能需要额外配置
  • 确保3389端口在防火墙中开放(代码中已提供示例)
相关文档:
C#强制关闭Windows Server系统服务器远程桌面服务方法[3]
  http://29680.oa22.cn
该文章在 2025/3/7 16:56:06 编辑过
