ASP / PHP Cross Reference
2012年6月6日 23:32 本文热度 9634
This is by no means a complete list but it should help you convert ASP to PHP or the other way around. PHP has many more built in commands than ASP (VBScript), so several lines of code in ASP may convert so a single line in PHP. If you have a large application to move from ASP to PHP, the ASP Translator is a free web application that will save you hours of work. It converts comments, variables, if/then, loops, and many commands from ASP to PHP, all in your web browser.
ASP (VBScript)
PHP (v4.3+)
General syntax
ASP Comments, inline
'my dog has fleas
PHP Comments, inline
//my dog has fleas
ASP Comments, block
not available?
PHP Comments, block
ASP, Escaping quotes
"var text1=""<img src=\""blank.gif\"">"";"
PHP, Escaping quotes
\" or use ' like javascript
'var text1="<img src=\"blank.gif\">";';
ASP Command termination
None, but only one command per line.
PHP Command termination
Each command must end with ; but
multiple commands per line are allowed.
ASP Screen output
response.write "hello"
PHP Screen output
echo "hello";
ASP Newline characters
vbCrLf
response.write "hello" & vbCrLf
PHP Newline characters
"\n" (must be inside "", not '')
echo "hello \n";
ASP Variable Names
Not case sensitive,
so fName is the same as FNAME
PHP Variable Names
Case sensitive AND must begin with $
so $fName is NOT the same as $FNAME
String Functions
ASP String concatenation
fname=name1 & " " & name2
emsg=emsg & "error!"
PHP String concatenation
. and .=
$fname=$name1." ".$name2;
$emsg.="error!";
ASP, Change case
LCase(), UCase()
lowerName=LCase(chatName)
upperName=UCase(chatName)
PHP, Change case
strtolower(), strtoupper()
$lowerName=strtolower($chatName);
$upperName=strtoupper($chatName);
ASP String length
Len()
n=Len(chatName)
PHP String length
strlen()
$n=strlen($chatName);
ASP, Trim whitespace
Trim()
temp=Trim(xpage)
PHP, Trim whitespace
trim() and also ltrim(), rtrim()
$temp=trim($xpage);
ASP String sections
Left(), Right(), Mid() Left("abcdef",3)
result = "abc"
Right("abcdef",2)
result = "ef"
Mid("abcdef",3)
result = "cdef"
Mid("abcdef",2,4)
result = "bcde"
PHP String sections
substr() substr("abcdef",0,3);
result = "abc" substr("abcdef",-2);
result = "ef" substr("abcdef",2);
result = "cdef" substr("abcdef",1,4);
result = "bcde"
ASP String search forward, reverse
Instr(), InstrRev()
x=Instr("abcdef","de")
x=4
x=InstrRev("alabama","a")
x=7
PHP String search forward, reverse
strpos(), strrpos() $x=strpos("abcdef","de");
x=3 $x=strrpos("alabama","a"); x=6
ASP String replace
Replace(string exp,search,replace)
temp=Replace(temp,"orange","apple")
temp=Replace(temp,"'","\'")
temp=Replace(temp,"""","\""")
PHP String replace
str_replace(search,replace,string exp)
$temp=str_replace("orange","apple",$temp);
$temp=str_replace("'","\\'",$temp);
$temp=str_replace("\"","\\\"",$temp);
ASP, split a string into an array
Split()
temp="cows,horses,chickens"
farm=Split(temp,",",-1,1)
x=farm(0)
PHP, split a string into an array
explode() $temp="cows,horses,chickens";
$farm=explode(",",$temp);
$x=$farm[0];
ASP, convert ASCII to String
x=Chr(65) x="A"
PHP, convert ASCII to String
$x=chr(65); x="A"
ASP, convert String to ASCII
x=Asc("A") x=65
PHP, convert String to ASCII
$x=ord("A") x=65
Control Structures
ASP, if statements
if x=100 then
x=x+5
elseif x<200 then
x=x+2
else
x=x+1
end if
PHP, if statements
if ($x==100) { $x=$x+5; } else if ($x<200) { $x=$x+2; } else { $x++; }
ASP, for loops
for x=0 to 100 step 2
if x>p then exit for
next
PHP, for loops
for ($x=0; $x<=100; $x+=2) { if ($x>$p) {break;} }
ASP, while loops
do while x<100 x=x+1
if x>p then exit do
loop
PHP, while loops
while ($x<100) { $x++; if ($x>$p) {break;} }
ASP, branching
select case chartName
case "TopSales"
theTitle="Best Sellers"
theClass="S"
case "TopSingles"
theTitle="Singles Chart"
theClass="S"
case "TopAlbums"
theTitle="Album Chart"
theClass="A"
case else
theTitle="Not Found"
end select
PHP, branching
switch ($chartName) {
case "TopSales":
$theTitle="Best Sellers";
$theClass="S";
break;
case "TopSingles":
$theTitle="Singles Chart";
$theClass="S";
break;
case "TopAlbums":
$theTitle="Album Chart";
$theClass="A";
break;
default:
$theTitle="Not Found";
ASP functions
Function myFunction(x)
myFunction = x*16 'Return value
End Function
PHP functions
function myFunction($x) { return $x*16; //Return value }
HTTP Environment
ASP, Server variables
Request.ServerVariables("SERVER_NAME")
Request.ServerVariables("SCRIPT_NAME")
Request.ServerVariables("HTTP_USER_AGENT")
Request.ServerVariables("REMOTE_ADDR")
Request.ServerVariables("HTTP_REFERER")
PHP, Server variables
$_SERVER["HTTP_HOST"];
$_SERVER["PHP_SELF"];
$_SERVER["HTTP_USER_AGENT"];
$_SERVER["REMOTE_ADDR"];
@$_SERVER["HTTP_REFERER"];
@ = ignore errors
ASP Page redirects
Response.redirect("wrong_link.htm")
PHP Page redirects
header("Location: wrong_link.htm");
ASP, GET and POST variables
Request.QueryString("chat")
Request.Form("username")
PHP, GET and POST variables
@$_GET["chat"];       @ = ignore errors
@$_POST["username"];
ASP, prevent page caching
Response.CacheControl="no-cache"
Response.AddHeader "pragma","no-cache"
PHP, prevent page caching
header("Cache-Control: no-store, no-cache");
header("Pragma: no-cache");
ASP, Limit script execution time, in seconds
Server.ScriptTimeout(240)
PHP, Limit script execution time, in seconds
set_time_limit(240);
ASP, Timing script execution
s_t=timer ...ASP script to be timed...
duration=timer-s_t
response.write duration &" seconds"
PHP, Timing script execution
$s_t=microtime(); ...PHP script to be timed...
$duration=microtime_diff($s_t,microtime());
$duration=sprintf("%0.3f",$duration);
echo $duration." seconds"; //required function
function microtime_diff($a,$b) {
list($a_dec,$a_sec)=explode(" ",$a);
list($b_dec,$b_sec)=explode(" ",$b);
return $b_sec-$a_sec+$b_dec-$a_dec;
File System Functions
ASP, create a file system object (second line is wrapped)
'Required for all file system functions
fileObj=Server.CreateObject
 ("Scripting.FileSystemObject")
PHP, create a file system object
Not necessary in PHP
ASP, check if a file exists
pFile="data.txt"
fileObj.FileExists(Server.MapPath(pFile))
PHP, check if a file exists
$pFile="data.txt";
file_exists($pFile);
ASP, Read a text file
pFile="data.txt"
xPage=fileObj.GetFile(Server.MapPath(pFile))
xSize=xPage.Size 'Get size of file in bytes
xPage=fileObj.OpenTextFile(Server.MapPath(pFile))
temp=xPage.Read(xSize) 'Read file
linkPage.Close
PHP, Read a text file
$pFile="data.txt";
$temp=file_get_contents($pFile); //Read file
Time and Date Functions
ASP, Server Time or Date
Now, Date, Time
PHP, Server Time or Date
date()
ASP, Date format (default)
Now = 12/8/2007 11:29:27 AM
Date = 12/8/2007
Time = 11:29:27 AM
Various ASP functions extract date parts:
Month(Date) = 12
MonthName(Month(Date)) = December
Day(Date) = 8
WeekdayName(Weekday(Date)) = Saturday
WeekdayName(Weekday(Date),False) = Sat
PHP, Date format
There is no default format in PHP.
The date() function is formatted using codes:
date("n/j/Y g:i:s A") = 12/8/2007 11:29:27 AM
date("n") = 12
date("F") = December
date("j") = 8
date("l") = Saturday
date("D") = Sat
Numeric Functions
ASP, convert decimal to integer
Int()
n=Int(x)
PHP, convert decimal to integer
floor()
$n=floor($x);
ASP, determine if a value is numeric
IsNumeric()
if IsNumeric(n) then ...
PHP, determine if a value is numeric
is_numeric()
if (is_numeric($num)) {...}
ASP, modulus function
x mod y
PHP, modulus function
$x % $y
Links:
该文章在 2012/6/6 23:42:58 编辑过
