Asp生成条形码源码
2012年9月25日 0:40 本文热度 8631
一个用asp生成条形码的例子代码。(注意:生成的图形为html代码,而非图片,打印时,请在IE的Internet选项=>高级=》打印 选定“打印背景颜色和图像”)
更简单的方法就是使用条形码字体,下载:http://www.51windows.net/2004/share/font/tiaoma.rar(如果地址无法下载,请在Google上搜索"条形码 字体")。
<html>
<head>
<meta http-equiv="Content-Type" content="text/html; charset=gb2312">
<meta name="Keywords" content="51windows.Net">
<META NAME="Author" CONTENT="haiwa">
<title>Asp生成系形码</title>
<style>
* {font:menu}
</style>
</head>
<body>
’条形码生成程序
’海娃@2004-4-4
’http://www.51windows.Net
function haiwaocde(zfstr)
zf = zfstr
zf = replace(zf,"0","_│_│__││_││_│")
zf = replace(zf,"1","_││_│__│_│_││")
zf = replace(zf,"2","_│_││__│_│_││")
zf = replace(zf,"3","_││_││__│_│_│")
zf = replace(zf,"4","_│_│__││_│_││")
zf = replace(zf,"5","_││_│__││_│_│")
zf = replace(zf,"7","_│_│__│_││_││")
zf = replace(zf,"6","_│_││__││_│_│")
zf = replace(zf,"8","_││_│__│_││_│")
zf = replace(zf,"Array","_│_││__│_││_│")
zf = replace(zf,"a","_││_│_│__│_││")
zf = replace(zf,"b","_│_││_│__│_││")
zf = replace(zf,"c","_││_││_│__│_│")
zf = replace(zf,"d","_│_│_││__│_││")
zf = replace(zf,"e","_││_│_││__│_│")
zf = replace(zf,"f","_│_││_││__│_│")
zf = replace(zf,"g","_│_│_│__││_││")
zf = replace(zf,"h","_││_│_│__││_│")
zf = replace(zf,"i","_│_││_│__││_│")
zf = replace(zf,"j","_│_│_││__││_│")
zf = replace(zf,"k","_││_│_│_│__││")
zf = replace(zf,"l","_│_││_│_│__││")
zf = replace(zf,"m","_││_││_│_│__│")
zf = replace(zf,"n","_│_│_││_│__││")
zf = replace(zf,"o","_││_│_││_│__│")
zf = replace(zf,"p","_│_││_││_│__│")
zf = replace(zf,"r","_││_│_│_││__│")
zf = replace(zf,"q","_│_│_│_││__││")
zf = replace(zf,"s","_│_││_│_││__│")
zf = replace(zf,"t","_│_│_││_││__│")
zf = replace(zf,"u","_││__│_│_│_││")
zf = replace(zf,"v","_│__││_│_│_││")
zf = replace(zf,"w","_││__││_│_│_│")
zf = replace(zf,"x","_│__│_││_│_││")
zf = replace(zf,"y","_││__│_││_│_│")
zf = replace(zf,"z","_│__││_││_│_│")
zf = replace(zf,"-","_│__│_│_││_││")
zf = replace(zf,"*","_│__│_││_││_│")
zf = replace(zf,"/","_│__│__│_│__│")
zf = replace(zf,"%","_│_│__│__│__│")
zf = replace(zf,"+","_│__│_│__│__│")
zf = replace(zf,".","_││__│_│_││_│")
haiwaocde = zf
end function
code_H = 52
code_W = 2
function dragcode(ccode)
c = ccode
c = replace(c,"_","<span style=’height:"&code_H&";width:"&code_w&";background:#FFFFFF’></span>")
c = replace(c,"│","<span style=’height:"&code_H&";width:"&code_w&";background:#000000’></span>")
dragcode = c
end function
function dragtext(ccode)
c = ccode
dragtext = ""
for i=1 to len(c)
dragtext = dragtext&"<span style=’width:26;text-align:center’>"&mid(c,i,1)&"</span>"
next
dragtext = dragtext
end function
Function CheckExp(patrn,str)
Set regEx=New RegExp
regEx.Pattern=patrn
regEx.IgnoreCase=true
regEx.Global=True
CheckExp = regEx.test(str)
End Function
code = request("c")
if code = "" then
code = "*51windows.net*"
else
if Checkexp("^[abcdefghijklmnopqrstuvwxyz12345678Array0\+\-\*\/\%\$\.]*$",code) then
code = "*"&code&"*"
else
errstr = "<br><center style=’color:red;’>含有非法字符 </center>"
end if
end if
ocode = code
code = lcase(code)
<center><form name="form1" method="post">合法字符:ABCDEFGHIJKLMNOPQRSTUVWXYZ 12345678Array0 + - * / % $ .<br><br><input name="c" type="text" value="<%=request("c")%>" size="25" maxlength="15"> <input type="submit" name="Submit" value="提交"></form><center>
<div align="center">
<center>
<table border="0" cellpadding="0" cellspacing="0" height="7Array">
<tr>
<td height="61" align="center"><%=dragcode(haiwaocde(code))%></td>
</tr>
<tr>
<td height="18" align="center" style="text-align:justify;text-justify:Distribute-all-lines;"><%=(ocode)%></td>
</tr>
</table>
</center>
</div>
<%=errstr%>
</body>
</html>
该文章在 2012/9/25 0:42:13 编辑过
