SQL中AS的用法和经典SQL语句大全,提升你的数据库查询技能!
2026年4月15日 15:1 本文热度 5167
今天给大家整理了一些工作中常用到的SQL语句,特别是AS的用法,希望能帮助大家提升SQL查询效率!
一、AS的用法详解
AS关键字在SQL中主要用于为表或列指定别名,让查询结果更清晰易懂:
-- 为列指定别名select id, column1 * column2 as 计算结果 from table1
-- 为表指定别名select a.id, b.name from table1 as a, table2 as b where a.id = b.id
-- 子查询中使用别名delete table1 from (select * from table2) as t2 where table1.id = t2.id
二、实用SQL语句精选
二、实用SQL语句精选
1. 数据删除与清空
-- 根据子查询删除记录delete table1 from (select * from table2) as t2 where table1.id = t2.id
-- 快速清空表(速度快,但不记录日志)truncate table table1
2. 数据更新技巧
-- 方式一:子查询更新update table1 set column = column + 1 where id = (select id from table2)
-- 方式二:多表关联更新(推荐)update table1 set column = column + 1 from table1, table2 where table1.id = table2.id
3. 查询优化技巧
-- 使用NOT EXISTS代替NOT IN(性能更好)select table1.id from table1 where not exists (    select table2.id from table2     where table1.id = table2.id)
-- 多表联合查询select table1.id from table1, table2, (    select id from table3) as t3 where table1.id = table2.id and table2.id = t3.id
4. 模糊查询高级用法
-- 单字符匹配(_代表任意单个字符)select * from table1 where column1 like 'A_B_C'
-- 指定转义字符select * from table1 where column1 like 'SQL#_G_O' escape '#'
-- 字符集匹配select * from table1 where column1 like '[A]%' or like '[^B]%'
5. 全文索引搜索
-- 包含关键词select * from table1 where contains(column1, 'char1 or char2*')
-- 邻近查询select * from table1 where contains(column1, '前有 near 中有 near 后有')
-- 权重查询select * from table1 where contains(description,     'isabout(apple weight(.9), boy weight(.8), china weight(.7))')
6. 常用统计查询
-- 分组统计并插入insert into table1 select column1, count(column1) from table2 group by column1
-- 取前N条记录select top 10 * from table1 order by id descselect top 10 percent * from table1  -- 前10%的记录
三、经典实用案例
1. 复制表结构
-- 只复制结构,不复制数据select * into b from a where 1<>1
-- 复制数据到已存在的表insert into b(a, b, c) select d, e, f from a
2. 外连接查询
-- 左外连接select a.a, a.b, a.c, b.c, b.d, b.f from a LEFT OUTER JOIN b ON a.a = b.c
3. 日程提醒查询
-- 查询提前5分钟的日程select * from 日程安排 where datediff(minute, f开始时间, getdate()) > 5
4. 删除冗余数据
-- 删除主表中副表不存在的信息delete from info where not exists (    select * from infobz     where info.infid = infobz.infid)
5. 获取最小未使用ID
SELECT     CASE         WHEN EXISTS(SELECT * FROM Handle b WHERE b.HandleID = 1)         THEN MIN(HandleID) + 1         ELSE 1     END as HandleIDFROM HandleWHERE NOT HandleID IN (    SELECT a.HandleID - 1 FROM Handle a)
四、年度统计汇总(经典案例)
-- 各单位电话费年度统计SELECT     a.userper, a.tel, a.standfee,     TO_CHAR(a.telfeedate, 'yyyy') AS telyear,    SUM(decode(TO_CHAR(a.telfeedate, 'mm'), '01', a.factration)) AS JAN,    SUM(decode(TO_CHAR(a.telfeedate, 'mm'), '02', a.factration)) AS FRI,    SUM(decode(TO_CHAR(a.telfeedate, 'mm'), '03', a.factration)) AS MAR,    SUM(decode(TO_CHAR(a.telfeedate, 'mm'), '04', a.factration)) AS APR,    SUM(decode(TO_CHAR(a.telfeedate, 'mm'), '05', a.factration)) AS MAY,    SUM(decode(TO_CHAR(a.telfeedate, 'mm'), '06', a.factration)) AS JUE,    SUM(decode(TO_CHAR(a.telfeedate, 'mm'), '07', a.factration)) AS JUL,    SUM(decode(TO_CHAR(a.telfeedate, 'mm'), '08', a.factration)) AS AGU,    SUM(decode(TO_CHAR(a.telfeedate, 'mm'), '09', a.factration)) AS SEP,    SUM(decode(TO_CHAR(a.telfeedate, 'mm'), '10', a.factration)) AS OCT,    SUM(decode(TO_CHAR(a.telfeedate, 'mm'), '11', a.factration)) AS NOV,    SUM(decode(TO_CHAR(a.telfeedate, 'mm'), '12', a.factration)) AS DECFROM (    SELECT a.userper, a.tel, a.standfee, b.telfeedate, b.factration    FROM TELFEESTAND a, TELFEE b    WHERE a.tel = b.telfax) aGROUP BY a.userper, a.tel, a.standfee, TO_CHAR(a.telfeedate, 'yyyy')
五、性能优化小贴士
  1. NOT EXISTS比NOT IN快:特别是在子查询结果集较大时
  2. 使用TRUNCATE代替DELETE:清空大表时速度快得多
  3. 合理使用索引:经常查询的字段要建立索引
  4. **避免SELECT ***:只查询需要的字段
温馨提示:以上SQL语句在不同数据库(MySQL、SQL Server、Oracle)中可能略有差异,请根据实际情况调整。
该文章在 2026/4/15 18:08:54 编辑过
