SQL Server中查询使用CPU比较高的语句
2026年6月12日 22:5 本文热度 4482
SELECT TOP 10 s.session_id,
           r.status,
           r.cpu_time,
           r.logical_reads,
           r.reads,
           r.writes,
           r.total_elapsed_time / (1000 * 60) 'Elaps M',
           SUBSTRING(st.TEXT, (r.statement_start_offset / 2) + 1,
           ((CASE r.statement_end_offset
                WHEN -1 THEN DATALENGTH(st.TEXT)
                ELSE r.statement_end_offset
            END - r.statement_start_offset) / 2) + 1) AS statement_text,
           COALESCE(QUOTENAME(DB_NAME(st.dbid)) + N'.' + QUOTENAME(OBJECT_SCHEMA_NAME(st.objectid, st.dbid))
           + N'.' + QUOTENAME(OBJECT_NAME(st.objectid, st.dbid)), '') AS command_text,
           r.command,
           s.login_name,
           s.host_name,
           s.program_name,
           s.last_request_end_time,
           s.login_time,
           r.open_transaction_count
FROM sys.dm_exec_sessions AS s
JOIN sys.dm_exec_requests AS r ON r.session_id = s.session_id CROSS APPLY sys.Dm_exec_sql_text(r.sql_handle) AS st
WHERE r.session_id != @@SPID
ORDER BY r.cpu_time DESC
或者不换行:
SELECT TOP 10 s.session_id, r.status, r.cpu_time, r.logical_reads, r.reads, r.writes, r.total_elapsed_time / (1000 * 60) 'Elaps M', SUBSTRING(st.TEXT, (r.statement_start_offset / 2) + 1, ((CASE r.statement_end_offset WHEN -1 THEN DATALENGTH(st.TEXT) ELSE r.statement_end_offset END - r.statement_start_offset) / 2) + 1) AS statement_text, COALESCE(QUOTENAME(DB_NAME(st.dbid)) + N'.' + QUOTENAME(OBJECT_SCHEMA_NAME(st.objectid, st.dbid)) + N'.' + QUOTENAME(OBJECT_NAME(st.objectid, st.dbid)), '') AS command_text, r.command, s.login_name, s.host_name, s.program_name, s.last_request_end_time, s.login_time, r.open_transaction_count FROM sys.dm_exec_sessions AS s JOIN sys.dm_exec_requests AS r ON r.session_id = s.session_id CROSS APPLY sys.Dm_exec_sql_text(r.sql_handle) AS st WHERE r.session_id != @@SPID ORDER BY r.cpu_time DESC
​查询结果:
该文章在 2026/6/13 8:52:40 编辑过
